STR912FA (IAR Eval board) - Help on Startup files
rxkumar
Posted on July 08, 2008 at 20:25
rxkumar
Posted on May 17, 2011 at 09:54
I am using STR912FAW44x6 eval board from IAR.
The LED blinky program (RAM version)from ST library works fine.
I am trying to download and run the program (ROM version) from flash.
I am using the ST startup files (91x_init.s and Vectors.s) from
ST Micro STR91xFA Rev 2.0 Firmware Library (RVDMK).
The program control doesnt switch to /reach Main.
Advice on start up sequence, vectors, sample code etc.
Rgds,
Rushoth.
rxkumar
I'm using GreenHills MULTI V5.0.3(C compiler).
Rgds
Rushoth
