str9 spi port
r_lghoul
Posted on June 23, 2008 at 15:02
str9 spi port
r_lghoul
Posted on May 17, 2011 at 09:53
hello,
we are using SPI port as a master connected to onother MCU should we use pull up resistors in between because the signal could be visualized in oscilloscop without connection once we connect SPI master to slave the signal disapears
Thanks in advance
