2005-10-07 3:04 AM
2005-10-04 8:15 PM
hello,
in the evaluation board schematic the diskon chip 2000 is mapped to 4 different 8kB locations in the memory through various jumper settings.can you tell me why it is done so ?2005-10-07 3:04 AM
These 4 memory loactaions corresponds to the 4 possibility of Memory address at which DiskOnChip will be located.
It is not mapped to the 4 adress at the same time. There are only 2 jumpers for memory adress configuration . So you have the possibility to select only one of the fourth configuration.
