2005-07-26 9:44 PM
2011-05-17 2:36 AM
OK, got another one here, the specified range for the crystal on the ST90158 is 3 to 5 mhz. What happens if you use a slower crystal? This circuits I'm debugging uses a 2.4576 mhz crystal.
What are the possible problems? George Richardson Electrical Engineer Canberra Dover2011-05-17 2:36 AM
Yes you can use the said frequency but their is no garantee the device will work properly e.g ADC acuracy will not be according to the datasheet etc
