ST72334 Data EEPROM programming
Options
‎2006-01-26 8:35 PM
12 REPLIES 12
Options
‎2006-01-25 12:30 AM
Posted on January 25, 2006 at 09:30
Thanks a lot for your answer, I'm going to try this tonight or tomorrow, I'll tell you how it worked. Philippe :DOptions
‎2006-01-26 2:33 AM
Posted on January 26, 2006 at 11:33
Quote:
@eeprom unsigned short tab[4]; the compiler shows this error message .... works fine here... I also tried using the array and the code generated looks correct; maybe you can try just adding that line (plus the line in the linker file) in one of the examples provided and work from there. Regards, LucaOptions
‎2006-01-26 8:35 PM
Posted on January 27, 2006 at 05:35
Luca,
you are completely right, it is working, I don't know what I was doing before... :-W THank you again ;)
- « Previous
- 1
- 2
- Next »
