software interrupt
swiggers9
Posted on June 26, 2006 at 16:30
software interrupt
3 REPLIES 3
swiggers9
Posted on June 20, 2006 at 10:33
Is there any example code for configuring and handling of software interrupts??
Sander
swiggers9
Posted on June 21, 2006 at 05:05
I'm working in the Keil uVision3 IDE with the Keil CARM compiler.
I want to create a delayed software interrupt (with the lowest priority) after a given number of adc samples. In my test application I was also toggling some IO pins on port 2. While debugging it seemed that there was constantly an interrupt pending on the XTI (P2.8 --- P2.11).
Am I forgetting something or can I avoid this?
here is my code.
Code:
int main(void)
config_interrupts(DISABLE);
config_irq_channel_priority(IRQ_CHANNEL_XTI, IRQ_PRIORITY_XTI);
config_irq_channel(IRQ_CHANNEL_XTI, ENABLE);
XTI->CTRL |= 0x02;
config_interrupts(ENABLE);
void adc_isr(void)__arm
if(sample_cnt == 30)
// activate delayed interrupt
XTI->SR |= 0x01;
void xti_isr(void) __arm
XTI->PRH = 0x00;
XTI->PRL = 0x00;
XTI->SR = 0;
//handle adc samples
swiggers9
Posted on June 26, 2006 at 08:48
Can you tell me what the effect of __swi(8) is?? aint this function being handled as any other function?
I want my software interrupt to be handled after all other pending interrupts with higher priority (like ADC, uart and timers) by setting a flag. But my code it doesn't seem to work and I can't find any examples of handling swi from the XTI.
Regards,
Sander
