2023-12-22 1:17 AM - last edited on 2023-12-22 4:43 AM by Peter BENSCH
SGS report indicates Test sample: LEAD FRAME; Item no.: C7025-UPG RT, the substance normally include Cu/Ni/Si/Mg, but according to M34E04B-FMC9TG material Composition Declaration file, the substance include Cu/Fe/Zn/FeP, please advise if the substance is correct or not.
2023-12-22 1:02 PM
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
