.s files in USB Library are not compilable with IAR EWARM
chander
Posted on July 29, 2005 at 06:11
chander
Posted on July 28, 2005 at 06:51
I am using IAR EWARM compiler for building USB Library Demo project.
I found that the .s files in the library are not compilable with this compiler. I think there is some directives etc. which are not supported. Does anybody have rectified these files for being able to be compiled by this compiler ??
Chander
chander
Posted on July 29, 2005 at 04:23
Thanx Zouh, I am able to compile these files now. But I am also getting a lot of errors in C files also. Could you send me the C files also if you have already modified these files.
Thanx in advance.
[ This message was edited by: chander on 29-07-2005 07:54 ]
chander
Gr8. I am able to build the executable now.
Thanx for the help.
