2003-12-12 8:41 PM
Programming both the Flash memory remotely
2011-05-17 2:57 AM
I am able to download the new application image on primary flash while executing from secondary(boot) flash.& vice versa. NOw i would like to know,if we ensure that there is no power failure,in that case can we make routines such that eg. Start execution from CSBOOT0 chk for valid image on primary flash,if found jump to primary flash Execute from the primary flash, try to program/ modify the CSBOOT0 With this , we can anytime program any of the flash while executing from other . Purvi
