Trouble when trying to download demo program to N6570-DK.
Einstein_rookie_version
Why its not letting me to erase the memory, what happened ?
STM32CubeProgrammer v2.19.0
ST-LINK SN : 0029002A3033510335393935
ST-LINK FW : V3J13M4
Board : STM32N6570-DK
Voltage : 3.29V
SWD freq : 8000 KHz
Connect mode: Hot Plug
Reset mode : Software reset
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device name : STM32N6xx
Device type : MCU
Device CPU : Cortex-M55
BL Version : --
Opening and parsing file: fsbl_cut_2_0_sign.bin
Memory Programming ...
File : fsbl_cut_2_0_sign.bin
Address : 0x70000000
Erasing memory corresponding to sector 0:
Erasing external memory sector 0
Error: failed to erase memory
Voltage : 3.29V
SWD freq : 8000 KHz
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device type : MCU
BL Version : --
Opening and parsing file: Project_ootb_v0.5.0.bin
File : Project_ootb_v0.5.0.bin
Address : 0x70080000
Erasing external memory sectors [8 16]
Voltage : 3.29V
SWD freq : 8000 KHz
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device type : MCU
BL Version : --
Opening and parsing file: network_data.hex
File : network_data.hex
Address : 0x70180000
Erasing external memory sectors [24 75]
Voltage : 3.29V
SWD freq : 8000 KHz
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device type : MCU
BL Version : --
Opening and parsing file: gfx_appli.bin
File : gfx_appli.bin
Address : 0x71000000
Erasing external memory sectors [256 264]
Voltage : 3.29V
SWD freq : 8000 KHz
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device type : MCU
BL Version : --
Opening and parsing file: ebike_appli.bin
File : ebike_appli.bin
Address : 0x71200000
Erasing external memory sectors [288 300]
Voltage : 3.29V
SWD freq : 8000 KHz
Device ID : 0x486
Revision ID : Rev Z
Revision ID : Rev Z
Device type : MCU
BL Version : --
Opening and parsing file: gfx_assets.hex
File : gfx_assets.hex
Address : 0x72000000
Erasing external memory sectors [512 1374]
Julian E.
Hello @Einstein_rookie_version ,
What demo are you trying to use exactly?
Here is an example of what you should generally be done:
  • Set the Boot pins to the right
  • Plug the DK board via the ST link to the PC
  • Open CubeProgrammer
  • COnnect the board with the green button on the right
  • Go to external Loader (bottom left button) and look for the DK board
  • Chek the box
  • Go back Erasing & Programming
  • Select your file
  • Click Start programming
Have a good day,
Julian
Julian E.
  • Chek the box
  • Select your file
Have a good day,
Julian
