2004-05-25 2:57 AM
problems to install STVPTD on XP machine
2004-04-07 3:26 AM
I have just installed visual debug ver. 2.5.4 but when i start the debug it does not work and display this error message: connection error (LPT1) : gdi-error in dvp: communicator error
can you help me?? thank you2004-04-07 9:56 PM
Hi Lino,
Which debugger are you using?2004-04-08 12:18 AM
hi friul,
i use STVD7 development kit and the board is ST7MDT1/MDT5-DVP2 kit board. OS is HP professional ver. 2002 SP12004-04-08 12:19 AM
hi friul,
i use STVD7 development kit and the board is ST7MDT1/MDT5-DVP2 kit board. OS is XP professional ver. 2002 SP12004-05-06 11:43 AM
Hi lino,
Are you using this on a laptop? What parallel port mode is set in your BIOS?2004-05-25 2:57 AM
HI MD,
thanks in advance for your reply, i changed the parallel port set but the wrong go on. I resolved my problem in this bad way: i format hard _disK and re-install windows XP and then STVD7. I don't known what is the difference but now the system work!!
