2008-09-21 5:22 PM
problem of STR912 IAP using Ethernet
2011-05-17 12:55 AM
If new firmware contains Ethernet code , the problem appears after IAP download this firmare. The part(Ethernet code) of firmware can not work well. But After Reset, the programme jump directly to firmware and the part(Ethernet code)of firmware can work well. why?how to solve it? Thanks
