2004-01-07 02:10 AM
2004-01-03 07:55 AM
What changes occured between the transition from ST62T10B to ST62T10C? Does this affect code?
Many thanks2004-01-07 02:10 AM
The difference between ST6210B and ST6210C is of option byte. In C version you can configure the option byte while with B version this option is not available.
There is not any effect on code because of transition from B to C.
