2024-04-08 01:07 AM
Will you please confirm on below part numbers that whether there will be any change in electrical parameters of the affected MPN depending on their PCN. For that do we need to verify any electrical parameters again?
Part Type | PCN Tracking No | Type of Change | Change Description | Affected_MPN |
Transistor | ADG/23/14438 | Manufacturing process change | Change from Etched leadframe version Stamped leadframe version. | STL120N8F7 |
Transistor | ADG/23/14402 | Manufacturing process change | Metallization : change in metal layers | STL130N8F7 |
2024-04-08 09:43 AM
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
If anyone else has similar types of questions regarding PCN, PTN, EOL, please feel free to open a support case directly at: http://my.st.com/ols
Regards,
Billy
