2004-05-25 01:28 AM
2004-05-17 02:00 AM
I get a (linker?) error: ''linkfile.lkf :1 segment share size overflow '' does anyone have an idea, what this means? Cheers.2004-05-17 02:53 AM
Your linker file (.lkf) is not correct.
Attach it here and we could possibly help further, also what memory model are you using? Regards sjo2004-05-17 10:52 AM
OK, I attach my LKF File!?
I use the ST7Flite Thanks [ This message was edited by: metabo_ms on 17-05-2004 23:26 ] ________________ Attachments : test2link.lkf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Dl&d=%2Fa%2F0X0000000bVf%2Fi60Ekn.RdexuXEW_g0QOiqECLwBZgPg1kqIC23f7ETg&asPdf=false2004-05-25 01:28 AM
What are your compiler options? Are you using the +lite0 directive? Can you post your makefile? Cheers, Martin.
