Laptop Parallel Ports
‎2003-12-01 3:04 AM
‎2003-11-19 9:34 PM
I have a Customer using a DELL Lattitude D800 laptop, with Windows XP. The Customer is using version 2.5.3 of ST Visual Debug.
He is unable to communicate with his ST7MDT2-DVP2. However, he has tried a very old version of the software (1.0.3, I know its old), and this works fine. I have sent him various 2.x.x versions to try, to try and determine which versions work OK with his laptop. I have used the STVD 2.5.3 and DVP under XP on a desktop and various laptops without a problem. I can only assume this is a parallel port issue at the moment. We have tried all the various modes, Normal, Bi-di, ECP. Any ideas?- Mark as New
‎2003-11-23 11:32 PM
ST7 Visual debug ver 2.5.3 is compatible with Windows XP. So the problem may be due to the Parallel port of your laptop. What's the error message are you getting?
‎2003-11-24 6:19 PM
Is the DVP as old as the STVD7 version?
‎2003-11-27 4:00 AM
Thanks for the replies.
Apparently, no error message appears. When the debug button is pressed, the software just waits indefinately. I know this is not enough information to base a conclusion on, so I have given the Customer a disc full of previous STVD versions. I should be getting the results back soon. If a previous 2.x version works OK, then this will give us some idea of where the problem lies?- Mark as New
‎2003-11-27 11:22 PM
What is the status shown at the right hand corner? Does it say ''Running'' or ''Reset'' or...? Maybe,your application is not coming out of reset?
‎2003-12-01 3:04 AM
Sometimes the address of the parallel port is not standard on some laptop. Can you look in the BIOS how the parallel port is configured ?
