iNEMO-M1 SW package
‎2024-04-21 6:29 AM
i have the inemo-m1 board, bought waaay back in 2015... back then i remember i managed to work with some sample code from ST.
However years have passed... and would be great to find a download location for the sample code.
I have tryied searching the internet and ST website, but did not find anything... probably is such a old code...
Would be great to find it again... Thank you very much
Discontinued
‎2024-04-26 4:20 AM
Here are the contents of the former and obsolete CD, brought up to date a little. It also contains Dfuse, which is also obsolete and whose function has been replaced by the STM32CubeProgrammer.
Hope that helps?
Good luck
/Peter
‎2024-04-21 7:13 AM - edited ‎2024-04-21 7:14 AM
Correct, INEMO-M1 has long been obsolete, which is why there is nothing left for it. But I'll be happy to see what else can be found in old archives, please be patient.
/Peter
‎2024-04-21 12:38 PM
Hi Peter,
would be great to find something, i searched so much for that algorithm because i remember it used some quaternion algebra and a extended kalman filter which proved to be quite stable in terms of drift for more than 24 hours.
Now i have come back again to integrate this little inemo board into a antenna tracker.
I will wait, no worries
‎2024-04-26 4:20 AM
Hope that helps?
Good luck
/Peter
‎2024-04-26 6:58 AM
Yes, indeed this is the code that i have been searching for
I will place this sw package into a safe place :)
Thank you Peter, you are the best !!
