2022-10-25 08:40 AM
We will be using this part to drive 6 automotive contactors. Supply voltage is 12/24V.
2022-11-01 11:35 AM
Welcome, @Abidwe, to the community!
The maximum current is limited internally, depending on the application you can drive different currents. Details can be found in the data sheet, e.g. in tables 56 and 61.
Does it answer your question?
/Peter
2022-11-01 11:35 AM
/Peter
