2006-10-03 8:34 PM
2006-08-31 6:10 PM
We are using stpc atlas reference board. We are able to boot windows CE 5.0 on it. The Bios used is from GS. The Stpc atlas BSP is used to build the NK.bin The Bios when booting shows the Hard disk connected but after wince 5.0 loads there is no HDD in the storage manager. Can anyone help with this. Balaji2006-08-31 9:20 PM
You should add an environement variable STPC_IDE0 set to 1 in the IDE storage setting. Attached a screen show how to add a new environment variable to the storage device setting . ________________ Attachments : Variable-Setting.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtqJ&d=%2Fa%2F0X0000000aXi%2FXJ.HjoPbgpCsdUFs93IpKrEL5_zjqD8VAPOXNCkWZVI&asPdf=false2006-09-03 10:46 PM
hi,
Thanks for your previous reply I am using wince5.0 platform builder. I don't know how to set the environment variable for storage devices. using the platform builder version 5.0. can U help me with this. Thank you Balsara ________________ Attachments : test.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htsn&d=%2Fa%2F0X0000000aYJ%2F9yyRNrIjWUdeNJbK2z6WZ5KIoCeYblgEbC9G6qT9ZwY&asPdf=false2006-09-04 1:25 AM
hi,
I have booted WINCE5.0 with USB mass storage, Network card in PCI slot and Hard disk in IDE connector. Thanks for your help Now working to get on with CDROM Thanks Balaji2006-09-04 8:27 PM
In windows CE 5.0 I have connected harddisk as master and connected CDROM as slave. The hard disk shows up in the storage manager, But I could not find CDROM in it, can anyone help me with this. Thanks balaji2006-10-03 8:34 PM
completed wince with network,cdrom,harddisk and usb mass storage device.
going for slackware. Is tinybios compatible in atlas evaluvation board has anyone tried it thanks Balaji
