2007-07-06 5:55 AM
2011-05-17 2:31 AM
I have a 512k by 8 bit SRAM interfaced to an STR912FW44 via 8-bit multiplexed mode using CS0. Whenever I write a byte to it, it writes the same byte into 4 locations in the SRAM two bytes 10 hex apart in two places 100 hex apart. What am I doing wrong? The compiler is keil C.
