2006-07-13 1:04 AM
Error when building the uClinux kernel
2006-07-12 9:50 PM
Hi!
I´m getting an error when building the kernel. I am trying the use uClinux according to the Getting Started application note. It works until i get to the step: run the following command ''make lib_only''. Leaving directory ´tmp/uclinux-dist/uClibc/libc/misc/assert´ ***[_dir_assert] Error 2 From this point on several errors occur (all ''leaving directory'') and at last the zimage.bin is not built. Does anyone know what I´m doing wrong? For information: I´m trying to build the kernel in cygwin running on a WinXP machine. Thanks, Michael2006-07-13 1:04 AM
OK, thanks. But is it possible to compile an application independently from the uClinux image under cygwin?
