Error register
Options
2005-11-01 7:42 PM
1 REPLY 1
Options
2005-10-31 7:58 AM
Posted on October 31, 2005 at 16:58
I am Du Liu, software engineer of ballard Power systems. Right now I am working on the EEPROM Emualtion with XFLASH on ST10-276 microprocessor. I have following questions:
1. The ST10-276 User Manual says that the error bits in Flash error register (FER) has to be software reset. Can I reset it by writting zero to it? 2. Can I continue to program or erase XFLASH memory when these error bits are set? Thank you. Du Liu
