dynamic memory usage
egemen_gl
Posted on January 22, 2009 at 08:33
1 REPLY 1
egemen_gl
Posted on May 17, 2011 at 11:32
I'm trying to use dynamic memory allocation on str912FAW44 but the debugger(using Keil uVision3 IDE and Keil Ulink2 debugger) gives me errors at run time:
- ''Non-Aligned Access: Thumb Instruction at 0000C072H, Memory Access at 0000C230H''
- ''*** error 65: access violation at 0x00080000 : no 'execute/read' permission''
here are the code statements :
''UBYTE *ptr;''
''ptr=(UBYTE*)calloc(10,sizeof(UBYTE));''
I dont have any idea about the problem. Why this code is trying to access to a non-permitted area ? Could anyone please help me ?
Thank you.
