2005-05-05 3:14 AM
2005-05-03 11:31 PM
I cant open my realview debugger v1.6.1. The startup warning states the following : Cannot obtain license for RVD IDE Support (feature st_rvd_ide_D97137A7) with license version >=1.6: Feature has expired Feature: st_rvd_ide_D97137A7 Expired date: 30-mar-2006 License path: C:\Program files\ARM\Licenses\license.dat FLEXIm Error: -10,32 For further information, refer to FLEXIm End User Manual, available at ''www.macrovision.com''. Specify the command line option '-cmd' to start RealView Debugger in non-graphical mode. Pls advise.2005-05-05 2:16 AM
hi,
i've managed to solve the problem. It seems that I accidently adjusted the time clock of my taskbar to the date that exceeds the expiry date. When I adjusted it back to the real time, it wouldn't work. So, what I did was uninstall the whole IDE and install it back. It works fine now. Thanks anyway.
