Component identification
Semator
Hello everyone, I have problem with IC identification. Marking is D300I , 90A819. Pls let me know what kind of IC it is.
Vcc pin i the 1st pin, and GND is 8th pin, that's all I know.
5 REPLIES 5
Joe WILLIAMS
Hi Semator
This post has been escalated to the ST Online Support Team for additional assistance.  Should anyone else have a similar question about Part Identification, please submit your request directly to the ST Online Support Team at https://my.st.com/ols
Kind Regards
Joe
STMicro Support
TD300 ?
https://www.datasheetcatalog.com/datasheets_pdf/T/D/3/0/TD300IN.shtml
Close, but the supply voltage is around 15V, and it is between 1st and 8th pin, on td300 gnd is on 10th, but thank's for trying to help
Had to guess without some in-context photo.
You have other boards with this on? What is it driving? Stepper Motors? Audio Amps?
Indeed, you need to give more context and what application that circuit is involved?
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
