Compiler bug 4.5.5
Options
‎2007-09-11 10:30 PM
2 REPLIES 2
Options
‎2007-09-10 3:58 AM
Posted on September 10, 2007 at 12:58
Hi There,
Can anyone came across this problem ? Here is my problem: I want to locate my function pointer array to code memory area. Here is how my code looks like: void (* const Fptr[GRIP_MENUS])(void) = { CheckGHome, CheckGBandp, CheckGPNap, CheckGripMax, CheckGRHome, CheckFingerC, CheckFingerC, CheckSpread, CheckWrap, BandClicks, NapkinClicks, TopClicks, NULL }; As per my knowledge, when you have declared a variable .const it should go to 0xc000 to 0xffff segment. ( I am using COSMIC compiler 4.5.5 and my processor is ST72621) Instead it generates this error .... #error clnk Debug\diagnosis.lkf:1 bad address (0x1f5) for zero page symbol _Text >>This was generated by V4.5.5 >> PLEASE NOTE THAT THE SAME CODE HAS DESIRED EFFECT WITH REV 4.2e of compiler. THE NEW REV has some problems identifying function pointers with .const qualifiers. Any ideas ?Options
Posted on September 12, 2007 at 07:30as I explained directly to you, the problem comes from the code, where the same variable is declared @near once and @tiny (implicitely) in another file. The old compiler was less strict for this kind of check. Regards, Luca (Cosmic)
