2003-09-08 12:27 AM
2003-08-09 1:02 AM
Hi to all,
I have a short question : on STVD7 when I tried to run a program with output compare interrupt fCounterClock=fTIMER (1mS) (like the ex. Lite0 Ex6a.asm) the simulation don't work !! The same program with fCounterClock=fCPU, the interrupt work !!! SomeOne know why ?? Tanks in advantage MKBS2003-08-10 3:16 PM
This is a bug, it can't work.
2003-08-11 4:27 AM
Can i have the code used by you?
2003-08-11 7:46 AM
Hi Ranjeet,
this is the simple code ! mbks ________________ Attachments : constant.asm : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I09q&d=%2Fa%2F0X0000000bWg%2F6OfW2vNuM4hs5U8s9MOHXNnonFe.U.k5i4bU56BCxz8&asPdf=falseex6a.asm : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0A9&d=%2Fa%2F0X0000000bWf%2FOqdIKh3VpNH9zh3iLhtZaC7tcAzlqvxdPzs51BrSqaU&asPdf=false2003-08-26 2:02 AM
Yes, it is a limitation.
2003-09-08 12:27 AM
The bug has been notified to the tools development group and will be corrected in the next release of STVD7.
