Step by step with SOFTEC STVD7
jps
Posted on August 07, 2008 at 06:09
jps
I've just a little problem using step by step debug in Softec STVD7. With the previous version, I could see the text assembly line hightlighted in yellow at each step. Now, I can only see the dissasembly code in yellow and nothing happens on the text line so it's very difficult to follow! Do anybody have a solution to that? Is there a setting to get the step by step monitoring in the text file instead of the dissasembly?
Thank you for your help.
