Write memory error @ address 0x5C002000, word access: Memory access timeout
enricol
Posted on November 19, 2007 at 09:47
4 REPLIES 4
enricol
Posted on May 17, 2011 at 09:33
Hi All,
I could flash my STR912 dongle with no problem before. This morning, I suddenly got the following error when I re-flashed the unit:
''Write memory error @ address 0x5C002000, word access: Memory access timeout.''
Is this caused by hardware fault (JLink or the board)?
Any help is very much appreciated.
mark9
I had the same problem. I am able to recreate the situation that kills the chip! It appears to be a bug in the C-SPY interface, in that if the chip gets misconfigured, it is impossible to regain control.
The problem occurred when 91x_conf.h was misconfigured. I forgot to uncomment the #define _GPIO2 line. When the GPIO2 was configured, it was using 0x00000000 as the base address instead of the proper memory location ((GPIO_TypeDef *)GPIO2_BASE). When it configures the (wrong) GPIO input, it immediately crashes. Even worse, you can't exit this state using the IAR tools!
What I did to exit the state was to use Keil uVision and ULINK to completely erase the chip. Then I was able to switch back to IAR and the j-link to step through the code until I found the problem.
I can understand that misconfiguring the CPU can break the debugger, but there really should be a way for IAR/J-link to regain control by fulling erasing the chip. I can't find this feature in IAR EWARN.
Mark
yuantuh
Hi Elai,
If you are using the IAR board, please make ETM_P66 pin 2-3 close and
ETM_P67 pin 2-3 close.
Yuantu
m_tibu
I had the same problem as Mark (lakata) described.
http://www.st.com/mcu/forums-cat-4846-21.html
Unfortunately it seems that it can not be solved, using Jlink with IAR environment just trying to reprogram the flash memory, because it gives the error above.
I was not able to erase the flash memory also using a simple wiggler circuit with openOCD. With my wiggler circuit I was not able to halt the ARM core that has this problem.
I solved the problem using another Jtag interface with openOCD for ftdi chips. (Amontec Jtag-Tiny key). I think the secret is to manage correctly the reset pin (there are more then one) on the jtag interface. Maybe this Amontec Jtag interface do it correctly. I had no time to check the difference between a RESET from Jlink and Amontec key.
Maybe there is an issue in the GPIO port configuration.
Check your firmware.
Marco
