why spwf04sc write data to socket server no action after several successful write action?
Wsl
(1) My spwf04sc Module work in AP mode with SPI interface. Firmware version is 1117. The module open socket server on .
(2) Only read data(no write) from socket server which come from PC is OK . (SOCKDR) Read once every 30ms . The Module can receive data successfully.
(3) Only write data(no read ) to socket server once per 30ms to PC has problem.(SOCKDW) ---Pc can receive former several frame data successfully. ---But after that ,when write command head to module, the module no action and INT GPIO9 keep conastant high and not change to low .
The spi Bade rate is 10M. So what's problem ? and How to recovery from this except reset ?
0 REPLIES 0
