2008-01-15 05:44 AM
Where is the c1823.zip file containing ECC software for NAND FLASH MEMORY?
2008-01-10 02:38 PM
Dear all,
As you can see in AN1823 application note, the c1823.zip file containing ECC software to download from www.st.com. It's too bad that search engine cann't find in www.st.com web site. Could you send me a copy of c1823.zip? Best Regards!2008-01-14 05:37 AM
I didn't find an AN1823 on STR7 web site. From where did you download it?
2008-01-14 05:21 PM
This application is located at
2008-01-15 05:44 AM
Dear boole_deng,
It is mentioned in the AN , Examples of Software ECC are available from your local STMicroelectronics distributor. You need to contact your local distributor; it is not available on the web site. There is an AN ''How to connect a small page NAND Flash memory to STR710 '' An2287, this may helps you if you are working on STR710 product. ;-)
