Where can I find reliability data about endurance and data retention test for M24128-BFDW6TP?
SChen.12
4 REPLIES 4
Pierre P.
Senior III
​Hello,
You can find endurance & data retention in the datasheet and in Application note AN2014.
See at https://www.st.com/content/st_com/en/products/memories/serial-eeprom/standard-serial-eeprom/standard-i2c-eeprom/m24128-bf.html
section "Resources"
BR
Team EEPROM suPPort
SChen.12
Neither in datasheet and in Application note AN2014 cann't tell the description about Test Item, Test Method, Test Conditions and result for M24128-BF.
any other documentations?
Pierre P.
Senior III
​sorry for the mismatch I was focused on performance and not test method/conditions.
This informations are confidential and included in the qualification report which is confidential document. It can't be communicated thru this channel.
Your request has been forwarded to an ST local representative.
BR
Thanks for your reply J Best regards, Susanna Chen Serial Microelectronics Inc. 30268新竹縣竹北市光明六路87-1號3樓之1 TEL: 886-3-6575 255 # 867 Mobile: 0955-552122 web : <> http://www.serialmicro.com/
