2004-12-24 10:57 PM
WARNING L2066: Variable _startupData not found, linker prepares no startu
2004-12-02 05:47 PM
hi all
i am compiling a piece of code . The *.o file are made successfully but after that i get warning WARNING L2066: Variable ''_startupData'' not found, linker prepares no startup .Can anybody help me why this error is coming . i am using Hiware Compiler thanks in advance Ronnie2004-12-24 10:57 PM
Hi
I think this warnning may be removed by adding start07.o to your .prm file I think you'll find 3 versions of it in your compiler/linker directories. I think that you don't have to add this file always and you may ignore this problem Salam Hossam
