Using STR75x data memory as EEPROM
ucoskun
Posted on October 08, 2009 at 12:39
3 REPLIES 3
ucoskun
Posted on February 12, 2008 at 06:49
Hello friends. I want to use STR75x data memory (Bank1 Data Memory) as EEPROM. But I can't see any functions like ''FLASH_WordWrite'' or ''FLASH_WordRead'' in STR75x library. How can I perform this operation? Can you please give me an idea? I'm using Keil. Thanks.
starfish844
Posted on September 17, 2009 at 06:28
i have a problem like you. I cant access flash bank1 to write data. If you overcome this problem, could you let me know?
Thank you
jgoril
Hi. Try the following flash library from ST:
http://www.st.com/stonline/products/support/micro/files/str7xfpmsw.zip
