2014-09-01 12:34 AM
What is the range of capacitor sizes recommended to AC couple the substrate (exposed paddle) to ground? A 0.22uF is shown in the Application Note AN3961. Is there a limit on maximum size? Can the substrate be connected to the most negative HV supply?
#sthv748 #ultrasound2014-09-16 11:49 PM
Dear Reel,
your question is clear, yes, the substrate, througth the exposed pad, it si preferable to filter it by a HV capacitor connected to clean GND, in principle there is no limit to the maximum value of this capacitor. It can also be connected to HVM0. Best Regards Giulio Ricotti
