Starting Problems
gerke
Posted on April 12, 2008 at 05:51
Starting Problems
gerke
Posted on April 05, 2008 at 15:50
i'm trying to make a project with the str755fr2t6.
For the Reset-Pin i'm using the STM1813LWXF.
But i have still problems with the starting. If i switch off the power for 30 seconds or longer, the programm will not start. Then i must reset the µC and the programm runs.
What can be the problem that the programm is not running at the first try?
b.r.
Jörg Gerke
gerke
The problem was a bad soldering joint on one of the boot pins
