2008-04-11 08:51 PM
2008-04-05 06:50 AM
i'm trying to make a project with the str755fr2t6. For the Reset-Pin i'm using the STM1813LWXF. But i have still problems with the starting. If i switch off the power for 30 seconds or longer, the programm will not start. Then i must reset the µC and the programm runs. What can be the problem that the programm is not running at the first try? b.r. Jörg Gerke2008-04-11 08:51 PM
The problem was a bad soldering joint on one of the boot pins
