ST7FLITE10 programming tool, any available??
anellohome
Posted on January 09, 2004 at 18:34
4 REPLIES 4
anellohome
Posted on January 09, 2004 at 14:57
HI!
Any working, available tools for programming ST7FLITE10?
Must be compatable with the model ''10'' for this device family.
None on the web mention useablility with this device.
Only ST7FLITE15 or *19 mentioned.
dominique2
Posted on January 09, 2004 at 15:04
No problem, the FLite10 is supported by the same programming tools (ST7 MDT10-EPB, ST7-STICK...) as the FLite15 and FLite19.
Download the latest version of the ST7 Visual Programmer, v 1.9.1 ,
http://www.stmcu.com/modules.php?name=mcu&file=mdtdocs
anellohome
Posted on January 09, 2004 at 16:11
Thanks jugnon.
I downloaded as you mention, and suspected as such.
But, I am actually looking for a portable device,
like the units from Segger (Flasher) or a Key Fob (Kanda) type units.
Have you (or anyone else...) successfully tried these products
or similar on the ST7FLITE10?
sjo
You will have to build one but Flashbash supports the FLITE10 in standalone and pc mode.
www.spen-soft.co.uk
sjo
