ST72F324J6 PWM Output pin
brian4
Posted on December 03, 2003 at 12:51
brian4
Posted on December 03, 2003 at 07:08
Is the PWM output (OCMP1A) on Port F bit 4 effected by the DDR & the OR or does the the PWM write to the Pin/Pad directly.
I want an open drain output from the PWM.
Is this achievable?
[ This message was edited by: BrianM on 03-12-2003 11:39 ]
jatin
Posted on December 03, 2003 at 12:26
When an alternate function is used , alternate function takes priority our standard I/O programming. When signal is coming from on-chip peripheral, that pin is automatically configured in O/P mode(push-pull or open-drain) depending up on the peripheral used. So, it is not possible to change this configuration.
brian4
Many thanks
