2007-05-27 09:14 PM
2007-05-27 09:14 PM
When I use the input capture mode on timer A the MCU go in reset.
The code sequence is: _asm(''rim'') (PORT INIZIALIZATION) TACR2 = 0x08; //fcpu/8 TACR1 = 0x80; //''IC'' interrupt _asm(''rim'') AT THIS POINT THE MCU RESET. I use the same code on ST7C334N4 and work good. Now, what is the problem?
