ST7 problem
pete3
Posted on September 16, 2005 at 07:07
ST7 problem
pete3
Posted on September 15, 2005 at 10:49
Hi all,
I have narrowed a code error down to this loop:
while(!(CMSR & 0x01))
CMCR |= 0x01;
from which the COSMIC compiler generates the following absolute listing:
1235 850d 2002 jra L572
1236 850f L372:
1237 ; 444 CMCR |= 0x01;
1238 850f 1068 bset _CMCR,#0
1239 8511 L572:
1240 ; 441 while(!(CMSR & 0x01))
1241 8511 0169fb btjf _CMSR,#0,L372
The problem is that the code is entered and runs either once or twice (normally twice, ~70% chance) but then code execution stops! I have checked this using SCI comms code and code immediately after this loop will not run. Code before this runs as expected.
Does anyone have any ideas? I am programming the micro through an inDART ST7 which works fine.
alok2
Posted on September 16, 2005 at 04:25
What is the purpose of this code ? CMSR is a register ? Why loop is running 2 times , it shall be always once
change it to
if (!(CMSR & 0x01))
CMCR |= 0x01;
pete3
Sorry alok,
CMSR is a status register. To put the CAN peripheral into initialisation mode, you need to set bit 0 of the CMCR register. It will then enter that mode when it is not receiving anything. I cannot guarantee that the module is doing nothing when this code runs, but the next lines require that the CAN module is in initialisation. When bit 0 of the CMSR is set, the module is in initialisation mode.
My problem is that this code executes fine but that the line directly after it never executes.
