ST4SI2M0020TPIFW Device marking information
Vijay Soundararajan
Hi
Our incoming inspection unit failed to find any information on ST4SI2M0020TPIFW device marking and it's datasheet.
Kindly confirm the same
8944477200
000753575
Peter BENSCH
Welcome, @Vijay Soundararajan, to the community!
This is an eSIM with security features, so a datasheet is not generally available and the public community cannot help you. Please contact either the online support team OLS and create a ticket for personal support or your preferred local distributor.
If the problem is solved, please mark this thread as answered by selecting Accept as Solution, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
2 REPLIES 2
Peter BENSCH
Good luck!
/Peter
Okay, Thanks to ST team.
