ST10F276 Read setup time
urik
Posted on March 07, 2006 at 08:45
5 REPLIES 5
urik
Posted on March 07, 2006 at 03:15
what is the data set-up time when i use the demuxed bus, with no read delay?
is that T15 ?
if so does it means that the setup time is 18.5 ns? or if i use a 55 ns SRAM i can latch the data after 55ns and not 55 + 18.5 ns?
thanks,
Uri.
najoua
Posted on March 07, 2006 at 05:12
Yes, the data set-up time when using the demuxed bus, with no read delay is t15.
If Fcpu = 40Mhz: t15= 18.5 + tc (ns) & tc = 2TCL x (15 - MCTC) ; with 15 - MCTC is the number of wait states.
--> so t15 value is Fcpu and external memory access time dependent.
Let's take an example:
ST10 Frequency is 40 Mhz. Thus the CPU cycle is 25ns. Assuming that the memory has an access time of 55ns= 25ns + 30ns, in order to access this memory, 2 wait states should be
inserted in the EBC cycle.
In this case:
t15= 18.5 + 25x2 = 68.5ns.
If CPU Clock is Variable (from 1 to 64MHz):
t15 = 3TCL – 19 + tC.
I hope i was clear.
Najoua.
[ This message was edited by: Najoua on 07-03-2006 09:44 ]
urik
Posted on March 07, 2006 at 05:51
Najoua Hi,
you were not so clear , does the T15 <= 18.5 + Ext mem acc time
or T15 <= Ext mem acc time - 18.5 ?
if i am not worng for 55ns i need 3 wait states?
can you please clear this point?
thanks,
Uri.
najoua
Posted on March 07, 2006 at 07:04
Hi Ukatry,
I will clarify,
t15 <= 18.5 + tc;
tc = 2TCL x (15 - MCTC) which depends on Fcpu and the number of wait states in order to be able to acceed the memory.
For a memory having an access time of 55ns:
- at least 2 wait states must be added when Fcpu = 40Mhz because: 55 ns = 25 ns + 30 ns and 30/25 = 1.2 so 2 waitstates are needed.
- at least 3 wait states must be added when Fcpu = 64 Mhz
because: 55 ns = 15.6 ns + 39.4 ns and 39.4/15.6 = 2.5 so 3 waitstates are needed.
I hope it is clear now.
Najoua.
[ This message was edited by: Najoua on 07-03-2006 11:39 ]
urik
now it is clear , thank you very much.
