ST10F269 Flash Read Failure...
eric4
Posted on January 10, 2005 at 08:49
1 REPLY 1
eric4
Morning everyone!
I have a problem with my ST10 flash:
I program unused locations in the chip to 0xFF i.e. same as erased value. A periodic check of the complete flash chip sometimes reads a 0xFF value as 0x7F (this happens on average once every 5 times the memory is checked, but typically is random).
Is it possible that when programming an already erased location to 0xFF, that there can be a smaller charge applied holding the state of the flash 'bit' than if I program the value with, e.g. 0x00?
And could this explain why I sometimes read a 0x7F when I should be reading 0xFF?
Thanks all,
Eric Watson
