RLink connection
lseletron
Posted on September 13, 2007 at 04:40
RLink connection
1 REPLY 1
lseletron
I am using RLink and ST72F264G2.
I can program the chip, read option byte etc., but I cannot use it to debug.
When I press (in STVD7)the ''Start Debugging'' button it asks me to reduce the sector size to 0.5K and after that it says ''Chip not responding after user reset: check power supply and clock source options''.
There is power and I try with both option byte enabled and disabled, to no avail.
Thank you
