2005-08-19 02:30 AM
2005-08-18 05:23 AM
I'm using STR710.
I would like to create an exact 1ms periodic interrupt routine.I have not found yet, how to modify the counter-register.2005-08-19 02:30 AM
Thank you very much for the good example, it works and I understand it now. Is it right, that the timer0-function does not need any output-pins? in your example the Pin P0.1 is only to show the time, isn't it? Thanks, by
