Package information for M93C66-WDW6TP EEPROM
RStäb.1
To introduce the EEPROM M93C66-WDW6TP I need the following information:
  1. Number of soldering cycles
  2. Orientation (the position of the component in the tape / tray)
  3. Packing dimensions stock(Dimensions of the reel / tray / tube)
  4. Packing type(The dimensions of the tape)
  5. Parts per container(The number of components on the reel / tray / tube)
  6. Solder profile reflow ( J-STD-020 )  we need a reflow profile
  7. Weight (Weight of the component)
Thank you for your help.
Pierre P.
Senior III
See below my comments.
Additional documents are sent to you by message.
  1. Number of soldering cycles: Compliant to JEDEC 020E: 3
  2. Orientation (the position of the component in the tape / tray): Pin 1 at the top left when sprocket holes at the top
  3. Packing dimensions stock(Dimensions of the reel / tray / tube): Tape & Reel 13�?
  4. Packing type(The dimensions of the tape). See documents sent.
  5. Parts per container(The number of components on the reel / tray / tube): 4000
  6. Solder profile reflow ( J-STD-020 )  we need a reflow profile: See documents sent
  7. Weight (Weight of the component): 34mg
BR
Pierre
Pierre P.
Senior III
BR
Pierre
RStäb.1
thank you for the answer. Thats exactly that was I need.
Richard
