on program CAPS command - log message Device secured
emilmih
Posted on May 11, 2007 at 19:24
emilmih
Posted on May 17, 2011 at 09:42
Hi
When I try to program my STR912-SK with configuration using CAPS
it gives me log message
Start JTAG operation...
Device 1 : ( 4 pins )
Device is secured. Select all regions for erase operation.
Time elapsed : 1 sec.
And I don't think the config is programmed
When I erase ALL everything is OK
Regards Emil
mark9
There are 2 other reasons why you get the
''Device is Secure. Select all regions for erase operation''
1. No power on the device
2. *slow* power up of the device. I discovered that if I apply 1.4V before 3.3V (ie ramp up my external power supply over the course of seconds), the device will not turn on at all. For this reason, we are putting in an external voltage supervisor, since the internal LVD doesn't seem to work well (I've verified that the LDV is enabled in the config bits).
The stupid CAPS program does not distinguish between a secured device and an unpowered device.
