2007-01-03 10:45 PM
2006-12-26 10:23 PM
I am using OCDremote to programming the STR7 embedded flash. I am not able to run the monitor commands in OCDremote.''command not found'' error is coming.what changes needed for gdbinit file? I would appreciate your help in this regards. can you suggest me other ways to programmming embedded flash of STR7. Thanks
