2007-01-04 10:46 PM
2006-12-26 10:14 PM
I am using OCDremote to programming the STR7 embedded flash. I am not able to run the monitor commands in OCDremote.''command not found'' error is coming. I would appreciate your help in this regards. can you suggest me other ways to programmming embedded flash of STR7. Thanks
